vlxiim
Feb 28, 2020Tutor
Apple TV and iOS products not staying connected.
My set up: RAX120 with 2 EX8000's 6 Apple TV's, 9 Apple iOS Devices. 5 AV recivers, Smart TV's 8 PC's, 3 Printer's 6 Amazon echo devices Ring and security cameras Dozens of lighting and c...
Killhippie
Mar 03, 2020Prodigy
I have a iPhone 11 Pro AX a 3rd Gen iPad 12.9" and a 2017 iMac 27" all have never had connection issues , running in AX mode with OFDMA and MU-MImo on, using 1.0.1.118 started life on 1.0.0.84 but have factory reset inbetween each update, coinsidering the updates added like OFDMA and Tx beamforming the consensus with most netegar routers let bleeding edge devices is to factory reset when after each update and do not use a config from previous firmware. A factory reset via the pinhole updating to 1.0.1.118 before hand should sort your issues out.
