vlxiim
Feb 28, 2020Tutor
Apple TV and iOS products not staying connected.
My set up: RAX120 with 2 EX8000's 6 Apple TV's, 9 Apple iOS Devices. 5 AV recivers, Smart TV's 8 PC's, 3 Printer's 6 Amazon echo devices Ring and security cameras Dozens of lighting and c...
vlxiim
May 08, 2020Tutor
RAX 120 still droping. I did the full reset on the rear of the router. Updated to 122 and still not working . I did the reset and kept it mostly at the defaults. On the Apple TV it'll come up, no network connection detected. If you go into the Apple TV settings it will show that the IP address is there but the subnet and DNS fields are all blank. Forgetting the network and reconnecting to the network solves the problem until it happens a day or two later.
Ar3
Aug 01, 2020Tutor
Did you ever get this issue resolved? I have something almost exactly the same:
