imkharn
Apr 30, 2020Aspirant
Apply button in port forwarding does nothing
Firmware 1.0.1.122 Advanced Setup>>Port Forwarding/Port Triggering>>Add Custom Service Service Name: Server Protocol: TCP External Port Range: 28967 Use Same Port Range for Internal Port: ...
imkharn
Solution found, bug is only in firmware 122.
https://www.netgear.com/support/product/rax120.aspx#Firmware%20Version%201.0.1.118
Downgrade to this firmware version resolved.
Christian_R
May 04, 2020NETGEAR Employee Retired
Hello imkharn,
Thanks for sharing your experience as it may help others who may experience the same issue.
Best,
Christian
