Corneileous
Sep 23, 2022Aspirant
Are there better antennas for the RAX41 router
Just as the title says, I’m curious if there’s better antennas on Amazon or so that are better than the ones that came with it, thanks.
Sep 23, 2022Guru - Experienced User
Anything is possible. Might be better high gain antenna available. I see these are detachable so technically you could swap out stock for something different. Other factors should be reviewed as well. Designed of the router is intended for use with that comes with the router. There maybe limiting or environmental factors that can contribute to good and bad wifi operations.
- CorneileousSep 23, 2022AspirantI did find out from a Netgear support agent that the antennas that come with this router are 3dBi and I did see some antennas on Amazon that claim to be around eight and 10 but there’s so many to choose from, I’m not really sure which ones would actually help or not.
If you don’t mind and if you have a couple minutes to spare, could you go on Amazon and look at probably the same antennas I was looking at and tell me if you know which ones would work or which ones you would choose?
I typed router antenna in the search bar and these were 3 types I thought would work.
Bingfu 4G LTE Cellular Trail Camera Antenna 8dBi RP-SMA Male Antenna (2-Pack) Compatible with Spypoint Link Micro Solar EVO Link S Dark Flex Wildlife Hunting Game Cam Outdoor Mobile Security Camera https://a.co/d/hhnyXfJ
Bingfu Dual Band WiFi 2.4GHz 5GHz 5.8GHz 3dBi MIMO RP-SMA Male Antenna (2-Pack) for WiFi Router Wireless Network Card USB Adapter Security IP Camera Video Surveillance Monitor https://a.co/d/1qNC7Bp
Bingfu Dual Band WiFi 2.4GHz 5GHz 5.8GHz 8dBi MIMO RP-SMA Male Antenna (4-Pack) for WiFi Router Wireless Network Card USB Adapter Security IP Camera Video Surveillance Monitor https://a.co/d/2SXcVr0
