craigscoffee
Oct 21, 2019Tutor
are you losing your port forwarding settings?
I couldn't figure this problem out, and I see online that people have been complaining about it for almost a decade. As soon as I upgraded to the RAX80 I started having this issue where you would e...
Busaman
Nov 16, 2019Aspirant
Bad news, it was a temporary fix and the issue reappeared only after a few minutes. I did another reboot and the port forwarding settings reappeared but I'm worried they'll just disappear when I log in at a later time. So the fix is if you need to make changes to your port forwarding rules is to reboot, hopefully they show to make the necessary changes.
craigscoffee
Nov 16, 2019Tutor
You need to disable all logging functions, not just clear the logs and reboot. There's a long list of things to uncheck. Once it stops logging, it won't erase your PF settings. Netgear really needs to fix this.
This fix has been working for me since I posted about it weeks ago.
- MacmanlexMay 07, 2020Aspirant
I am aving the exact same problem out of my RAX75 but this fix is not working. Any updates on it?
- craigscoffeeMay 07, 2020Tutor
I'm sorry to hear this trick isn't working for you. It's been a while since I looked at this. Did you completely disable logging, delete current logs, and reboot? If so, there maybe another issue.
Please respond to this thread if you find a different cause and solution.
- BusamanMay 07, 2020AspirantI still haven’t lost my port forwarding settings in a long time. I believe what I did was reset the router like new. Disable the logs and cleared any that are there before adding all the static IP and port forwarding rules. Hope this helps.
