BS50's avatar
BS50
Armor Free Trial Error
I had to reset to factory default settings on my RAX200.
Now when I go to the app on my phone (Android) Netgear Armor Security panel has an Activate Trial button. When selected I get a failed to subscribe error message.
I have tried rebooting the router
I have re-installed the app
I have turned on and off remote management
I have tried on another device
I have tried to go to Add ons in the app to purchase it (if available). The only option available is pro support. No help there.
Previous to reseting to factory defaults. The router set up with the free trial version of Netgear Armor working normally.
How do I get the free trial activated so that I can purchase it?
Firmware version v1.0.2.98
  • Christian_R's avatar
    Christian_R
    NETGEAR Employee Retired
    Hi BS50,
    May you send me a private message with your contact info and serial number. I'd like for our support team to reach out for further investigation.
    Christian
    • CAmbr52342's avatar
      CAmbr52342
      Tutor
      Hello, I just updated to the most recent firmware after completing a factory reset. I am experiencing the same problem. I cannot activate the trial so I can purchase Armor. I had an expired trial prior to uploading the newest firmware.
      • BS50's avatar
        BS50
        I am still working to resolve the problem...
