df2ef2f2f23f2ef
Aug 01, 2022Aspirant
arp invalid randomly with RAX200
Hi everyone, I have a RAX 200 with the latest firmware 1.0.10.140. However the below issue existed in previous firmwares too. Bascially randomly, machines in LAN can't talk to each other and ...
df2ef2f2f23f2ef
Aug 02, 2022Aspirant
Reset de router and did all setup manually again. Now ARP issue seems to be gone.
But, Lan port 1 doesn't assign IP anymore... Had to change to Lan port 2...
Unbelievable.. those issues. Never spent so much time on figuring out router issues. Again I say, never buy Netgear again. Rubbish.
Aug 02, 2022Guru - Experienced User
What CAT# lan cable are you using between the router and wired PC? CAT6 is recommended.
Does any wired device work on LAN port #1?
