Jared1012's avatar
Jared1012
ASUS Zenpad 8.0 refuses to connect to RAX15
I replaced an old Linksys with a RAX15. I kept the same SSID and password. Every device in the house connected to the new router without issue except an Asus Zenpad 8.0 (Z580CA) with WLAN802.11 a/b/g/n/ac. It picks up the SSID with excellent signal strength but everytime I try to connect it saves the network but comes up disconnected. I tried cycling the modem / router and reconnecting. I forgot the old network on the Zenpad. I tried connecting again. I retarted and tried adding the new network manually. I tried WPS push button and WPS pin. Some advice was to reset the network settings on the Zenpad. There is no option to do this on this model/GUI other than to forget the network in the wifi network listing. I toggled on/off smart connect. Other advice was to make sure the 2.4 channel wasn't higher than 1-11; it's on auto, but it doesn't go higher than 11 anyway. I don't think any of my other devices are 5G capable (I future-proofed), so I may try just turning off the 5G band. May also try a factory reset on the Zenpad. Other than that, I'm at my wits end. Any ideas would be appreciated.
  • michaelkenward's avatar
    michaelkenward
    To me this says that the problem is with your Zenpad.
    Tried that again?
    This WiFi 6 (AX) stuff is new. Old kit may not be happy. Tried disabling AX WiFi?
    • Jared1012's avatar
      Jared1012
      Thanks for the reply! It could be the Zenpad, although I've never had an issue with it connecting to any other network: friends, hotels, airports, etc. It's been around the world. I tried disabling AX; unfortunately, that didn't do the trick. It's a real mystery that at this point but bugs me enough that I don't think I can let it go.
