georgezpreston
Jul 16, 2020Aspirant
attacged devices not showing up R8000P
Used to I could see a list of attached devices, I dont know when it quit working but how can I get it back? Firmware Version V1.4.1.50_1.3.10 Runing Windows 10 I have used chorme, brave, the n...
Jul 16, 2020Guru - Experienced User
Have you tried rebooting the router?
georgezpreston
Yes and I have unplugged it and let it set for a while
- plemansJul 17, 2020Guru - Experienced User
If you really want the attached devices list, you could try a factory reset and reinstall.
https://kb.netgear.com/9665/How-do-I-perform-a-factory-reset-on-my-NETGEAR-router
