AliCairns
Aug 07, 2023Aspirant
attached devices
I just got a talking and hopefully listening bot on my browser but its telling me i have no microphones. I have speech recognition on my tv/monitor, i even have an amazon echo sat next to me. I have ...
- Aug 08, 2023
AliCairns wrote:
I think i saw that i can change netgear to an access point, is that better?
If you have network problems, that would be a good move. You then hit this:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
But that may not be important.
But again, I doubt if this will have any impact on the microphone problem. That is nothing to do with the routers. You should probably talk to the people who produced this unnamed "listening bot" for your browser.
microchip8
Aug 07, 2023Master
And this has to do with networking how exactly?
You also don't say which router, firmware version and modem you have!
AliCairns
Aug 08, 2023Aspirant
I need to ask about what i need to ask about.
Nighthawk AX11000 Tri-Band WiFi Router (RAX200) v1.0.10.140
- michaelkenwardAug 08, 2023Guru - Experienced User
That is down to whatever problem you have that involves the router.
As microchip8 says, the microphone problem described in your first message doesn't have much, if anything, to do with your router.
There is one warning message in your first post. You say:
I have a sky router with this one daisy chained onto it.
If that means that you have two routers on your network, that is asking for trouble. It will have nothing to do with your microphone issue, that is down to whatever microphone you have on whatever computer you are using. But it could cause other problems.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support- AliCairnsAug 08, 2023Aspirant
I would just have the netgear but i think sky says i have to have a sky hub for my q box.
