Xiong
Aug 15, 2020Aspirant
AX 12 Frequently disconnect from the unconnected network
v1.0.1.122 is the latest firmware. I cannot connect to the network, but the Wifi is connected normally. If there is no network, you need to restart the router to operate normally. The same problem ex...
Christian_R
Aug 20, 2020NETGEAR Employee Retired
Hello Xiong,
May you revert to the previous firmware version and see if the issue persists.
Thanks,
Christian
