crus4d3r_1211
Oct 14, 2022Aspirant
AX 1800 keeps rebooting
Just got myself this router 3 days ago and its constantly rebooting itself out of nowhere and its driving me up the wall. And before you ask, no this has nothing to do with the router overheating. I ...
- Oct 19, 2022
Well everything was in default settings, save for the SSID and the WPA2 key. That being said, I found a fix to my problem. It turns out that one of the light switches in my apartment controls the outlet the router is plugged into, and so I would often accidentally switch my router off when I was trying to turn off my lights. I also downgraded the firmware just to err on the side of caution.
crus4d3r_1211
Oct 15, 2022Aspirant
Look at the label on the device for the model number. Something like RAX###.
It's an RAX10
What firmware version do you have on the device?
V1.0.13.128
It might also help if you told people what the modem is in front of this router, if there is one. The make and model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
I don't have a modem because the ISP I'm using told me that I won't need one. I just plugged the router in straight to the ethernet socket I have at home.
michaelkenward
Oct 15, 2022Guru - Experienced User
That puts us in unknown (to me) territory.
That sort of Internet could be something like fibre, with your own Internet (WAN) IP address. Or it could be a network with its own router somewhere in the basement that shares a WAN address with everything on the network.
How you set up the router is down to your ISP. Have you asked them?
It's an RAX10
V1.0.13.128
That's the latest.
