Sewell1655
Jun 24, 2026Aspirant
AX-4 AX3000 RAX36 on/off schedule??
Hi all, This one is a few weeks old and every time I try to set the wifi on/off schedule.....off at 12:00 midnight....on at 6:00 am; it stays off the next morning. Have to go to the plugged in LAN l...
- Jun 24, 2026
Did you double-check that the time zone is correct? Most Netgear routers default to Pacific time.
Jun 24, 2026Guru - Experienced User
Sewell1655 wrote:every time I try to set the wifi on/off schedule.....off at 12:00 midnight....on at 6:00 am; it stays off the next morning.
- Sewell1655Jun 24, 2026Aspirant
Thanks Stephen,
I'm 99% certain I checked that but I'll look again.
Ken
Just checked the time zone Stephen.....was on Pacific!! Needed to be East Coast!!
Will see if it's on in the morning now.....
Thanks!!!
Ken
- Sewell1655Jun 25, 2026Aspirant
That was it Stephen......it's on now. Time zone now on Eastern.
Thanks for replying with that suggestion!!!!
On to the next headache!!
Ken
