Sewell1655
Jun 24, 2026Aspirant
AX-4 AX3000 RAX36 on/off schedule??
Hi all, This one is a few weeks old and every time I try to set the wifi on/off schedule.....off at 12:00 midnight....on at 6:00 am; it stays off the next morning. Have to go to the plugged in LAN l...
- Jun 24, 2026
Did you double-check that the time zone is correct? Most Netgear routers default to Pacific time.
Jun 24, 2026Guru - Experienced User
Sewell1655 wrote:every time I try to set the wifi on/off schedule.....off at 12:00 midnight....on at 6:00 am; it stays off the next morning.
Sewell1655
Thanks Stephen,
I'm 99% certain I checked that but I'll look again.
Ken
