Sewell1655
Jun 24, 2026Aspirant
AX-4 AX3000 RAX36 on/off schedule??
Hi all, This one is a few weeks old and every time I try to set the wifi on/off schedule.....off at 12:00 midnight....on at 6:00 am; it stays off the next morning. Have to go to the plugged in LAN l...
- Jun 24, 2026
Did you double-check that the time zone is correct? Most Netgear routers default to Pacific time.
Sewell1655
Thanks.....I'll try the 12:01 thing......
Ken
Sewell1655
Thanks....but the time can only be set by 1/2 hr increments.
The time zone was set to Pacific time. Needed to be Atlantic so that may have been the problem.
Will find out tomorrow morning!!
Thanks for the reply!!!
Ken
