Sewell1655
Jun 24, 2026Aspirant
AX-4 AX3000 RAX36 on/off schedule??
Hi all, This one is a few weeks old and every time I try to set the wifi on/off schedule.....off at 12:00 midnight....on at 6:00 am; it stays off the next morning. Have to go to the plugged in LAN l...
- Jun 24, 2026
Did you double-check that the time zone is correct? Most Netgear routers default to Pacific time.
Sewell1655
Yes,
They are definitely different routers. This one being two weeks old.
Will know, for sure, in the morning.
Still can't believe I had it on West coast time, instead of East!
The Netgear rep never suggested checking the time zone!!
Ken
