gpaspala23's avatar
gpaspala23
Follower
Aug 15, 2022
AX 4300 Nighthawk router disconnects every night since I upgraded the firmware
Did anyone find a solution for this issue. I am facing same issue and I am not sure how to fix it. Internet keeps dropping and only rebooting the router makes it work for few mins.
1 Reply
  • What model router do you have? AX4300 is a combined wireless speed, not a model#
    Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
