Robphx
Jan 16, 2020Follower
Ax 8 and Ax 12
I had an RAX80 for about a year . I recently took it back for return. The problem it developed was that it would stop working . The router would drop the WiFi so my home cameras like the ring doorbell...
GabboCH
Jan 16, 2020Apprentice
Sounds like you have the same experience as most RAX80 owners of the forum.
Unstable Wifi & the need to reboot often.
Mine is in the box on the shelf in the hope one day Netgear manage to get it working but after almost half a year without any feedback I have no confidence it will ever work.
As for Netgear products, I am currently using an EX8000 extender instead of the RAX80 and it has worked perfectly for the last 3 months. No reboots, no connection problems, stable speeds straight out of the box but as its an extender it is pretty limited in its additional features.
However, like you I am unlikely to recommend or take a chance on other Netgear products in the future with so many other brands out there.
