TexanJohn
Jan 21, 2021Tutor
AX Recommendation
Hello, I'm experiencing some intermittent issues with our internet service. I think it might be problems with our AC1900 (R7000) that is 7 years old. I was looking at the AX models. We h...
Jan 21, 2021Guru - Experienced User
How big is your home?
What are the interior walls made of?
Depending on the size, the $300 might be better invested in a system like the triband orbi's versus going up to AX.
AX is great but for a 200mbps, a decent orbi system will easily max that out and potentially provide better coverage. (i'd avoid the dual band orbi's)
- TexanJohnJan 21, 2021Tutor
2700 sqft, standard 2x4 with sheetrock for the walls
Because of the layout/length, currently I have two AC1900's. Each on one end of the house with the far one operating in AP mode (recieving a hardwire connection from the main AC1900).
I have concerns my main AC1900 is aging/failing, so possibly looking at a newer unit.
I will research the tri-band orbi's. Thanks.
- plemansJan 21, 2021Guru - Experienced User
The r7000 has had firmware issues for a while.
Some have revived them by using version 1.0.9.42 of the firmware. If you try it, install it over a hardwired connection, then do a factory reset, and a clean install (not from backup). Might be worth a shot as the r7000 should easily handle 200mbps.
