TexanJohn
Jan 21, 2021Tutor
AX Recommendation
Hello, I'm experiencing some intermittent issues with our internet service. I think it might be problems with our AC1900 (R7000) that is 7 years old. I was looking at the AX models. We h...
Jan 21, 2021Guru - Experienced User
How big is your home?
What are the interior walls made of?
Depending on the size, the $300 might be better invested in a system like the triband orbi's versus going up to AX.
AX is great but for a 200mbps, a decent orbi system will easily max that out and potentially provide better coverage. (i'd avoid the dual band orbi's)
TexanJohn
Jan 21, 2021Tutor
2700 sqft, standard 2x4 with sheetrock for the walls
Because of the layout/length, currently I have two AC1900's. Each on one end of the house with the far one operating in AP mode (recieving a hardwire connection from the main AC1900).
I have concerns my main AC1900 is aging/failing, so possibly looking at a newer unit.
I will research the tri-band orbi's. Thanks.
- plemansJan 21, 2021Guru - Experienced User
The r7000 has had firmware issues for a while.
Some have revived them by using version 1.0.9.42 of the firmware. If you try it, install it over a hardwired connection, then do a factory reset, and a clean install (not from backup). Might be worth a shot as the r7000 should easily handle 200mbps.
