tamefox
Feb 17, 2023Aspirant
AX series IP reservations
Looking to purchase a Netgear RAX120 / AX12 or similar in the UK.
Can anyone please confirm :
1) Does this allow up to 64 reserved IP addresses in DHCP?
2) Do all AX series allow up to 64 reserved IP addresses?
3) Do the reserved IP addresses have to be in or out of the DHCP allocation range, or either?
( so reserved IP addresses can be seen in different range to dynamic 'tourists' etc)
4) Do the reservations on this or other models allow a user-defined name/description to be entered?
( screen shots on online help/manuals are conflicting on this).
Thanks
You don't say, but have you checked the documentation for your options?
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done that already. I can't tell from your message.
I mention it because Netgear gave up on supplying paper manuals and CD versions some years ago and people sometimes miss the downloads.- tamefoxAspirant
Yup, but thanks anyway.
All documentation is suitably vague and/or lacking in screenshots that give clues.....
Many of these things have nothing to do with the models involved. They are down to the standards the brands use for their devices. After all, they all work on the basis of a limited choice of chipsets.
Rather than chase model details, try something like this:
AX series IP reservations - Google Search
As this is a standards thing, you may have to ignore the "AX" bit. That relates to the WiFi. Your question may have more to do with the rest of the router.
