mcullen5150
Apr 09, 2023Follower
AX12 AX600 wi-fi dropping
Gateway Fiber router connected to AX6000. Cat6 connecting routers. I had a R6900 when the wi-fi would drop several times during the day. It was 6 years old so I purchased the Nighthawk AX12 AX600...
michaelkenward
Apr 09, 2023Guru - Experienced User
Which ones? As Kitsap says, there are lots of AX6000s, Netgear makes about half a dozen, and there are dozens, or more, Gateway Fiber routers from different makers.
