mgdielman
Jan 01, 2023Aspirant
AX12 AX6000 Failing to setup after factory reset
My google nest and sonos systems recently stopped connecting to my AX6000 WiFi Router (RAX120) #, but wifi was still functioning. The Nighthawk app and default gateway failed to connect to the router...
- Jan 02, 2023
mgdielman wrote:
A new symptom if anyone has any thoughts: Router now will not turn back on after a 30-30-30 reset. Power light has been flashing slowly for ~30 minutes.
The firmware may be corrupt.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
mgdielman
Jan 02, 2023Aspirant
michaelkenward Is there a way to check the firmware version when I do not have access to the Nighthawk app or the router configuration page? Part of the issue is that 192.168.1.1 and routerlogin don't take me to the router configuration page so I have had limited access to troubleshooting info.
I don't have a modem that I have access to in front of the router, my ISP (WhyFly) has a building-wide setup with a rooftop access point and modem. However I can confirm that there are no changes to that access point and modem since it was working properly a few days ago, and that it is definitely not a modem/router combination.
michaelkenward
Jan 02, 2023Guru - Experienced User
I'm afraid I am not familiar with that sort of setup. If the whole building shares access from a single source, then the normal setup isn't relevant.
That rooftop box is probably some sort of router that has to connec6t all the different clients to the outside world. So you may be sharing a connection. That means that the standard setup fr your RAX120 isn't appropriate.
That may explain why you cannot get at 192.168.1.1 and routerlogin. That is a classic sign of a network conflict.
What is Double NAT? | Answer | NETGEAR Support
The best people to talk to should be the ones who run this Internet service. They should know how you can connect a router.
Famous last words. These things are called "networks" for a reason. They are a set of things connected to each other. Each depends on the rest of the chain.
Most people turn up here with conventional networks with a modem that connects them to the Internet. Anything else is a bit specialist.
- mgdielmanJan 02, 2023Aspirant
Unfortunately I already spoke with the ISP, that's how I know there were no changes made upstream since when it was working. The router stopped functioning properly while being used with no changes, and their instructions for setup were just to follow standard instructions on the router.
I do need to correct myself, 192.168.160.1 is the default gateway and what I was using to try to connect to. I can ping 192.168.160.1, but not access it in a browser,
- michaelkenwardJan 02, 2023Guru - Experienced User
Support | NETGEAR
Check the section in the manual Troubleshoot With the LEDs.- mgdielmanJan 02, 2023Aspirant
michaelkenward Thanks for the help. Manually updated firmware following those instructions and am now able to connect as expected once again.
