mgdielman
Jan 01, 2023Aspirant
AX12 AX6000 Failing to setup after factory reset
My google nest and sonos systems recently stopped connecting to my AX6000 WiFi Router (RAX120) #, but wifi was still functioning. The Nighthawk app and default gateway failed to connect to the router...
- Jan 02, 2023
mgdielman wrote:
A new symptom if anyone has any thoughts: Router now will not turn back on after a 30-30-30 reset. Power light has been flashing slowly for ~30 minutes.
The firmware may be corrupt.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Troubleshoot With the LEDs.
mgdielman
Jan 02, 2023Aspirant
Unfortunately I already spoke with the ISP, that's how I know there were no changes made upstream since when it was working. The router stopped functioning properly while being used with no changes, and their instructions for setup were just to follow standard instructions on the router.
I do need to correct myself, 192.168.160.1 is the default gateway and what I was using to try to connect to. I can ping 192.168.160.1, but not access it in a browser,
michaelkenward
Jan 02, 2023Guru - Experienced User
Support | NETGEAR
- mgdielmanJan 02, 2023Aspirant
michaelkenward Thanks for the help. Manually updated firmware following those instructions and am now able to connect as expected once again.
