rctvideo
Sep 07, 2019Aspirant
AX12 AX6000 Wifi Router losing password on devises
On several occasions one of two of my devises will not connect to the Wifi. When I connect is says it has the incorrect password. The devise connected before with the password that i installed. I ...
- Oct 11, 2019
Yes it works, the problems are solved
VelkySyr
Sep 08, 2019Tutor
rctvideo wrote:On several occasions one of two of my devises will not connect to the Wifi. When I connect is says it has the incorrect password. The devise connected before with the password that i installed. I will then sign in with the password and a messages comes back that it is the incorrect password. I know that it is 100% correct and other devises are stilled signed into the wifi.
The router will not let me log in either. I have to turn off the router and then back on. It will then let me sign in to the wifi with the password.
This is happening at least once or twice a week. What is the issue?
I am having the same issue with my router as well. This really needs to be addressed. While there is a workaround, it is not an acceptable way to have to manage the router, Other than this, which I do consider a big issue, the router is excellent in terms if every other aspect of its performance. NetGear, please get back to us on this,
