rctvideo
Sep 07, 2019Aspirant
AX12 AX6000 Wifi Router losing password on devises
On several occasions one of two of my devises will not connect to the Wifi. When I connect is says it has the incorrect password. The devise connected before with the password that i installed. I ...
- Oct 11, 2019
Yes it works, the problems are solved
Christian_R
Sep 20, 2019NETGEAR Employee Retired
Hello Nighthawk AX Community,
We currently have a trial firmware that may help resolve this issue. If you're interested, please send me a message.
Christian
- rctvideoSep 21, 2019Aspirant
Sure. I will try the firmware upgrade
- StreakyOct 17, 2019Aspirant
Hello, I have had this problem for some time on my router, an it's also happening to visitors trying to access my home WiFi. I have the latest firmware (1.0.1.56) - is this beta firmware out of beta yet? I'd dearly love to make this password issue go away.
Streaky
- Christian_ROct 18, 2019NETGEAR Employee Retired
Hi Streaky,
Would you mind confirming the model number of your device (eg. RAX120)
Thanks,Christian
- StreakyOct 21, 2019Aspirant
Firmware 1.0.1.56
