rctvideo
Sep 07, 2019Aspirant
AX12 AX6000 Wifi Router losing password on devises
On several occasions one of two of my devises will not connect to the Wifi. When I connect is says it has the incorrect password. The devise connected before with the password that i installed. I ...
- Oct 11, 2019
Yes it works, the problems are solved
Christian_R
Sep 20, 2019NETGEAR Employee Retired
Hello Nighthawk AX Community,
We currently have a trial firmware that may help resolve this issue. If you're interested, please send me a message.
Christian
rctvideo
Sep 21, 2019Aspirant
Sure. I will try the firmware upgrade
