rctvideo
Sep 07, 2019Aspirant
AX12 AX6000 Wifi Router losing password on devises
On several occasions one of two of my devises will not connect to the Wifi. When I connect is says it has the incorrect password. The devise connected before with the password that i installed. I ...
- Oct 11, 2019
Yes it works, the problems are solved
medic4085
Oct 11, 2019Aspirant
Christian_R,
Has anyone been able to confirm that the trial firmware worked? This was not a problem for me until about 1 month ago. Now I have to keep rebooting the router and it will fix the issue for a few days.
MTje
Oct 11, 2019Initiate
- Lambogini69Oct 31, 2019Aspirant
I am having the exact same issue with my RAX120
Firmware V1.0.1.90
Is there a release that is going to go out to fix this officially or are we needing to get the trial version still?
- Christian_RNov 04, 2019NETGEAR Employee Retired
Hello Lambogini69,
Welcome to the Community! May you update to the latest firmware version and let us know if your issue still persists.
https://kb.netgear.com/000061295/RAX120-Firmware-Version-1-0-1-100-Hot-Fix
Christian
