rctvideo
Sep 08, 2019Aspirant
AX12 AX6000 Wifi Router losing password on devises
On several occasions one of two of my devises will not connect to the Wifi. When I connect is says it has the incorrect password. The devise connected before with the password that i installed. I ...
- Oct 11, 2019
Yes it works, the problems are solved
Christian_R
Oct 18, 2019NETGEAR Employee Retired
Hi Streaky,
Would you mind confirming the model number of your device (eg. RAX120)
Thanks,
Christian
