sidekick3's avatar
sidekick3
AX12 IPV6 bug with wan link aggregation?
I'm trying to get IPv6 functional with WAN link aggregatation, but it doesn't seem to pass any traffic.  Settings are set to Auto Detect, and I'm running firmware v1.0.1.108.  It picks up IPv6 address, IPv6 DNS, and if I do an ipconfig /release and ipconfig /renew to grab ipv6, it does.  I try to ping ipv6.google.com, it resolves googles ipv6 address, however, ping timeout.  Pinging yahoo, resolves yahoo's ipv6 addy, but timesout trying to ping.  It never passes any IPv6 traffic.   I've tried every possible setting under IPv6, and nothing lets IPv6 traffic thru to the LAN or wifi.  I have to disable IPv6, and stick with IPv4.  It's as if there's an IPv6 firewall on the router not passing traffic, or it's not Nat'd.
I need IPv6 enabled to test our IPv6 webservers.  IPv6 works fine on my older R9000 that I'm upgrading from, but it's a no go on the AX12.   I'm assuming it has to do with wan link aggregation, as I haven't tried it without wan link aggregation, but that's the main reason I just upgraded to the AX12 from the R9000.
