mase
Sep 05, 2020Follower
AX12 IPV6 bug with wan link aggregation?
Has anyone else had this issue and were able to resolve it? I'm having the same exact issue as this post linked below: https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/AX12-IPV6-bug-with-wan-link-aggregation/m-p/1844496
1 Reply
- TopologyVirtuoso
Mase, as a point of reference, I am successfully using IPv6 with an RAX120 (1.0.1.128) router connected to a CM1200 (2.02.05, Comcast/Xfinity) modem with WAN port aggregation enabled.
What modem (and firmware) on which ISP are you using?
P.S.: To test your IPv6 connectivity, see here.
