BostonRob777
Feb 19, 2022Tutor
AX12 RAC 200
I am completely frustrated over this damn device. I lost all my wireless channels. Nothing is showing up. I’ve rebooted. Upgrade the firmware. This thing is a piece of crap.
Feb 20, 2022Guru - Experienced User
What actual device do you have? AX12 isn't a mode. And there isn't an RAC model. Maybe you mean the RAX200?
Is the wifi not broadcasting at all?
did you try pushing the wifi on/off button for 2 seconds?
- BostonRob777Feb 20, 2022Tutor
thank you for the reply. I had the model number wrong - RAX200 Nighthawk AX12
Wifi is broadcasting but the Netgear Nighthawk app no longers shows an expanded menu where you have parent controls and the ability to turn devices on/off. All this is now gone.
- plemansFeb 20, 2022Guru - Experienced User
so wifi is working? just having app issues with parental controls/access controls?
yes - wifi is working. The options in the app are all gone. See attached image. appears like my admin privs were downgraded.
