JohnD2d
Jun 01, 2022Aspirant
ax12 rax120 apps only not syncing with servers
outlook app and vodafone app and others not syncing with their servers they will work over 4g data but not wifi in this case im using samsunf galaxy a52s 5g and another android phone. funny thin...
Jun 01, 2022Guru - Experienced User
1. you have the rax120. what firmware is on it?
2. what modem/gateway is it connected to?
3. are you using the isp's dns servers or custom ones?
4. is ipv6 enabled?
