JohnD2d
Jun 01, 2022Aspirant
ax12 rax120 apps only not syncing with servers
outlook app and vodafone app and others not syncing with their servers they will work over 4g data but not wifi in this case im using samsunf galaxy a52s 5g and another android phone. funny thin...
Jun 01, 2022Guru - Experienced User
1. you have the rax120. what firmware is on it?
2. what modem/gateway is it connected to?
3. are you using the isp's dns servers or custom ones?
4. is ipv6 enabled?
JohnD2d
Hi
latest firmware installed for ax12 rax12o auto update then manual flash using latest firmware
connected wired to old d7000v2 in modem only mode works fine
dns set to primary 8888 secondary 8844 recommended by isp and netgear
ipv6 disabled
just apps problem on two android phones samsung
its a weird one.
- plemansJun 01, 2022Guru - Experienced User
So you're using an old D7000 as modem? Is that correct? Or what modem are you using?
And what actual version of firmware are you on? "the latest" isn't always, it changes, or the latest might not always be the best. Its why we ask.
Why did you disable ipv6? Some newer services are defaulting to that from the start.
did you try a different dns server than googles?
- JohnD2dJun 01, 2022Aspirant
firmware version 1.2.3.28 latest
the D7000v2 is a router/modem. because the router has failed this device i have set it to dsl modem only mode, connected by ethernet cable to new router.
DNS primary 8888 secondary 8844 recommended by isp
the ipv6 was disabled by default when i set the router up, oh and the new router is factory reset yesterday still ipv6 disabled
Do i need ipv6 in parrallel to ipv4?
I realize you're using google's dns server (8.8.8.8, 8.8.4.4) and that it was recommended to you. but sometimes its worth trying others like cloudfare.
Some websites are defaulting to checking for ipv6 connections first. And it can cause issues. Sometimes enabling ipv6 can help with that. Its why I was recommending trying.
