JohnD2d
Jun 01, 2022Aspirant
ax12 rax120 apps only not syncing with servers
outlook app and vodafone app and others not syncing with their servers they will work over 4g data but not wifi in this case im using samsunf galaxy a52s 5g and another android phone. funny thin...
JohnD2d
firmware version 1.2.3.28 latest
the D7000v2 is a router/modem. because the router has failed this device i have set it to dsl modem only mode, connected by ethernet cable to new router.
DNS primary 8888 secondary 8844 recommended by isp
the ipv6 was disabled by default when i set the router up, oh and the new router is factory reset yesterday still ipv6 disabled
Do i need ipv6 in parrallel to ipv4?
Jun 01, 2022Guru - Experienced User
I realize you're using google's dns server (8.8.8.8, 8.8.4.4) and that it was recommended to you. but sometimes its worth trying others like cloudfare.
Some websites are defaulting to checking for ipv6 connections first. And it can cause issues. Sometimes enabling ipv6 can help with that. Its why I was recommending trying.
