txbesmer
Mar 22, 2022Guide
AX12 RAX120 Constantly Rebooting
For the third time in a year, this router has started to reboot itself about 10 times per hour. I have 50+ wifi/wired devices connected. Current firmware v1.2.3.28 installed over 3 months ago. No ...
- Mar 23, 2022The last time this happened, I did do a factory reset. No help. That time I was inside the return window so I sent it back for another one. That’s the one I have now and it’s been solid for months since it too had the problem twice. Ruling out a defective unit. Update: I unplugged it for the overnight. Powering it back up in the morning, it’s been solid once again. Definitely a heat issue. I also have a mesh that records traffic to each connected device. One tablet running a surveillance camera stream had used over 7.5GB 2.4mhz streaming over a 2 hour period just before this started. I’ve disabled 2.4mhz WMM and the home assistant card responsible for the streaming. No more problems. Bottom line, this router cannot handle 2.4mhz streaming video. It will overheat.
txbesmer
Mar 23, 2022Guide
2xZyxel NWA50AX (POE). No change to them today or before this all happened. They run in AP mode, DHCP by the Netgear. They have been fine for hours, no router reboots since the POE camera integration in Home Assistant was removed. CPU load down below 10%. I don’t think the mesh had anything to do with the problem other than to route the traffic from the POE camera to the Wi-Fi connected tablet.
Mar 23, 2022Guru - Experienced User
Next time it happens, try disconnecting the mesh and rebooting the router.
Like I said, heat isn't going to increase the cpu processing but a stuck process can or something that's causing a loop on the network.
- txbesmerMar 23, 2022GuideAfter about 2 hours of reboots and troubleshooting, I disconnected Everything from the router, turned off the Wi-Fi with the push button on the device and tried to get it to start and stay on. It would not. Same issue. It’s been operating continuously all day with almost everything reconnected. The only thing that still won’t connect is my USB connected Drive that I use for cloud storage. It’s been an issue before and has never been a reliable connection. Readyshare has been a weak link on this router and I just read, Readyshare Vault is end-of-life. This might be the last straw for the USB connection. Probably moving to NAS. Incidentally, the USB drive was being used as a storage location for the POE camera feed in testing for that functionality if not using the SD Card in the camera.
- beachmilesMar 24, 2022ApprenticeDisable the 2.4ghz wmm in QOS settings if you have bad power and/or a non pure sine wave UPS. Switching to a pure sine wave UPS appears to have solved my Random reboots with 18 days of uptime where previously I would get 8 random reboots a day.
- txbesmerMar 25, 2022GuideI tried that as well. No difference in reboot performance. The USB connection seems to be more of a problem that contributes to my issues. I have a 6TB HDD connected and used as a storage device. If I start a back up job of greater than 10GB, the cpu usage climbs above 80% and the router will fail and start rebooting until I stop the backup job and disconnect the USB drive at the router. A final restart returns the router to normal operation. USB disconnected. The Wi-Fi was the connection method to the tablet that started the high drive usage and causing the initial failure. I don’t think the Wi-Fi was the problem. Just the connection to the root failure which is the USB drive. I’ve connected this drive directly to my desktop without issue. I’m going to try a different USB drive on the router next to test a smaller port-powered HDD.
