LeeH
Dec 23, 2019Prodigy
AX12 RAX120 Is not connecting with AX speed
I installed Intel Wi-Fi 6 AX200 cards in my ASUS and MSI laptops. I am only getting a 1200 Mbps connection to them no mater how close I am to the router. Is anyone getting AX speeds from their AX r...
Dec 23, 2019Guru - Experienced User
That's your problem right there. The iPhone 11 is only capable of 80hz channels. Not 160hz
digitsnbits
Dec 23, 2019Apprentice
I knew that but in order to get full AX speeds the client needs 160 channel support also.
I think he's looking for the speeds on the box and that's not going to happen.
1200 is pretty quick no complaints here, but then again I'm not using my RAX80 it's sitting in its box.
- plemansDec 23, 2019Guru - Experienced User
The AX200 from intel should be able to connect at 2400mbps if its properly running and if the router is properly running. I've had it connected at that speed to my RAX200 as well as another AX solution.
but the max for the Iphone is 1200mbps because of the 80hz width limit to iphones.
