Sentry
May 15, 2021Aspirant
AX12 RAX120 Not Working with DLNK Unmanaged Switch DGS-1024A
Hardware Version: RAX120 Firmware Version: V1.2.1.22 Operation Mode: Router Router not working when Dlink DGS-1024A switch is connected to one of the LAN ports. LAP Port seems to be flashing wh...
antinode
May 28, 2021Guru
> the LAN ports. [...]
Blame assignment is Job One. Does connecting some port on the Dlink
DGS-1024A to a LAN port on the RAX120 cause the problem, or does the
junk which is connected to the Dlink DGS-1024A cause the problem?
> [...] LAP Port seems to be flashing white [...]
What's a "LAP Port"? "seems"? Is there some doubt?
