Smart_ID10T
Aug 06, 2021Tutor
AX12 RAX120 Random Wifi disconnects
Hello All, This router has been a pain in the but, support has been lacking and slow... All my wireless devices will stop pinging my local network intermittently. Wired connections work just fi...
76Sporty
Aug 06, 2021Aspirant
i am having the same problems. i just purchased the ax12 rax120v2 (v1.2.1.22)router and it will not stay connected to the internet. trying to find a solution. hopefully someone here has solution/
- Smart_ID10TAug 06, 2021Tutor
Hey 76Sorty,
Can you stay connected to your local network or is yours just a issue with the internet? Also does your wired connection have the same issue?
- 76SportyAug 06, 2021Aspirant
i lose connection to my network. i connected directly to my modem (cm2000) with no problems(stable). i connect from my modem to the router and it seems every couple of minutes my network disconnects (wired and wireless)
