mystik
May 05, 2022Tutor
AX12 RAX120 Stability
I can only assume my hardware has gone bad. Because I used to have rock solid performance in the same place...everything in the same location and I am using the same devices, but now... I get disco...
mystik
May 05, 2022Tutor
Looking at the logs, I see a lot of entries like these. Not sure if these are blocked, or if it would even be related since wired seems fine, but just thought I would mention in case.
[DoS Attack: TCP/UDP Chargen] from source: 75.75.75.75, port 53, Thursday, May 05, 2022 17:50:03
[DoS Attack: ACK Scan] from source: 185.151.107.101, port 443, Thursday, May 05, 2022 17:49:28
[DoS Attack: SYN/ACK Scan] from source: 162.241.216.182, port 443, Thursday, May 05, 2022 17:23:39
The option to disable the protection in WAN setup is NOT checked.
EDIT: After looking a bit more closely, I doubt the number I am seeing are enough to cause this sort of behavior. BUT, I went ahead and disabled logging of attacks just in case.
