mystik
May 05, 2022Tutor
AX12 RAX120 Stability
I can only assume my hardware has gone bad. Because I used to have rock solid performance in the same place...everything in the same location and I am using the same devices, but now... I get disco...
May 06, 2022Guru - Experienced User
What firmware version are you on?
What modem/gateway is it connected to?
Have you tried a simple factory reset/reinstall?
If you stop the backup, does it function normally?
