betterfaster
Jul 09, 2024Guide
AX12 RAX120 v2 5GHz cuts out / stops working after connecting device to network
Router: AX6000 WiFi Router (RAX120) v2 AX12 Serial: 6JY FW: V1.2.9.52 (same running FW version for many months, solved reboots during USB SDD file transfer) When problem started: Between July 3 an...
betterfaster
Jul 09, 2024Guide
Contacting support is not an option because I went to the support page and it says my support and warranty is over. I had this router for almost 2 years now.. and it says to talk to the community instead.
