turtledivers
Jul 02, 2022Follower
AX12 RAX120
I am able to successfully connect my Apple iphones (Apple phones versions 11-13 with updated software) to my Nighthawk AX12 RAX120. However, once i do so, it seems the cell signal and the wifi signal...
Jul 02, 2022Guru - Experienced User
What version of the router do you have? v1 or v2?
How do you have the wifi and advanced wifi settings configured on the router?
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Set 20/40Mhz Coexistence to 40Mhz only. Set CTS to 2347. Under Advanced Tab/Advanced Settings/Wireless Settings
Also disable WiFi Private IP address on your phone as well:
