MB_82
Jul 11, 2020Aspirant
AX12 RAX200 band keeps changing by itself.
So, just installed my new router. The Internet is working fine. However, when I try to play World of Warcraft, I keep getting disconnected. It's only when playing. I noticed that after a disconnect t...
- Jul 11, 2020
/hMB_82 wrote:Thank you both for the advice!
I had the options in the attachment selected, I did not enable the smart connect, but I did have the OFDMA options selected. Not sure what that is, could that be the cause?
As far as channels, I left them on the default; 2.4 is on auto, 5GH1 is on 44 and 5GH2 is on 100. Should I turn down the transmission power on the two channels I don't want to use for gaming?
OFDMA is.a specific setting for 802.11ax devices to have dedicated subchannels used, not related...
With SmartConnect disabled, I'm a bit at a loss for why your device is switching to different WiFi networks..?
On your router, make sure you have a separate SSID for each one of the 3 networks.
Just to validate, can you remove all configurations for all 3 WiFi networks from your computer? Then just add one of them (perhaps one of the 5Ghz ones)?
Your computer won't automatically be able to switch unless it's be configured to accept the others.
Tri-band Wifi isn't intended for a single device to be on 3 bands, but rather to spread devices across all 3 bands for more optimal WiFi capacity.
Also thanks for the screenshot, made it easy to understand these WiFi settings.
Jul 11, 2020Guru - Experienced User
The RAX200 does bandsteering. Meaning it'll switch devices between bands as needed based on distance, interference, rssi, bandwidth, etc.
If its causing issues with gaming, you can disable it and set seperate names for each band.
- rinthosJul 11, 2020Luminary
plemans wrote:The RAX200 does bandsteering. Meaning it'll switch devices between bands as needed based on distance, interference, rssi, bandwidth, etc.
Agreed, I would suggest turning off band streering (Netgear calls it SmartConnect I believe). Create a separate WiFi network for each band and you should be in good shape. Either that, or you may want to change the channels being used for each wifi band..but my guess is your computer fan/gpu when busy (or if CPU is maxed) is creating some sort of hiccup and latency and Netgear is trying to "fix" it by moving your computer to another wifi band, which really isn't a fix.
Could also be WiFi drivers on your computer, so worth a shot updating those as well...
- MB_82Jul 11, 2020Aspirant
- lmanpunkJul 11, 2020Star
It is a horrible product. If you still have time, send it back. Maybe Netgear will trade straight up the Orbi RBK753S for RAX200 because the RAX200 is a connection dropping piece of crap. You can go through all the various troubleshooting in these forum but you would better off sending it back if you just got it.
