SERSX
Aug 30, 2020Guide
AX12 RAX200 Drops connections Wi-Fi & ethernet
Ok so of course my router starts acting up after the 90 day customer support. This unit keeps disconecting my connection to the internet at least once a day at random times. I have a PS4, Xbox, TV and...
ricozamora
Sep 02, 2020Tutor
I'm having the EXACT same issues you are having, it's been driving me nuts trying to figure this out to the point where I'm just going to go back to Linksys router I was previously using that had zero issues! Hopefully Netgear figures this out so I end up with a "supposedly great" product instead of a very expensive paper weight!
SERSX
Sep 03, 2020Guide
I had an older wifi 4 nighthawk x6 tri band and that one was really good untill it was not one day it just dropped all signals had to rest the unit to get it back up and running after a few months of and couple resets along the way because that one was also experiencing a sort of disconnection aswell I made the transition to this item RAX200 and it was good for the first few months then it just started this weird disconnecting issue.
