TrotterX
Jun 07, 2020Star
AX12 RAX200 keeps disconnecting WiFi and ethernet
Hi my RAX200 keeps randomly disconnecting WiFi devices and Ethernet but not always all devices sometimes it will disconnect 5ghz devices and keep 2.4ghz and Ethernet and be connected to the modem and ...
Jun 09, 2020Guru - Experienced User
I've seen multiple issues with the superhubs in "modem only" mode to where it isn't working properly.
Have you tried putting it back in router mode (disable its wifi) and run the RAX in access point mode? it stinks to do because it disables the routing function on the RAX but if it makes the connection stable, it might be worth it.
TrotterX
Jun 09, 2020Star
That has crossed my mind but then that sparks another question why would you have Netgears flagship router and only run it as an access point I’d be better off buying a cheaper access point and just leaving the super hub to do all the routing which is pants at it when you have a network of over 50 devices
- TrotterXJun 09, 2020StarAlso I had amplifi Hd set as a mesh with the super hub on modem modem with the amplifi doing the routing with no problems then I upgraded to a netgear XR500 and turned the amplifi HDs in to access points with the netgear doing the routing also no problems and I then decided to upgrade to the RAX200 mainly to make use of WiFi 6 and that’s when the problems started 🤦♂️
- plemansJun 09, 2020Guru - Experienced User
Have you tried running the super hub in router mode and then putting the netgears ip address in the superhubs dmz?
Did you try the ipv6?
- TrotterXJun 09, 2020StarHi I’ve just switched IPv6 on in auto mode and clicked apply it updated the settings and set it to 6to4 tunnel is that correct ? Everything seems to be connected at the moment only time will tell and I’m not all that of an expert on this home networking thing what is a DMZ and how would that work if you dont mind me asking 🤔
