TrotterX
Jun 07, 2020Star
AX12 RAX200 keeps disconnecting WiFi and ethernet
Hi my RAX200 keeps randomly disconnecting WiFi devices and Ethernet but not always all devices sometimes it will disconnect 5ghz devices and keep 2.4ghz and Ethernet and be connected to the modem and ...
RajaDaja
Jun 15, 2020Luminary
I’ve had a stable connection for about a week, no disruptions whatsoever! I’m on previous firmware (1.0.2.8 ) which allows ipv6 thru my ISP. New firmware 1.0.2.8.88 breaks a lot of things in my case( no ipv6, daily disconnects, frozen network.....
- RajaDajaJun 15, 2020LuminaryOne of my wi-fi 6 devices(iPhone 11 Pro) is getting almost 900 down! See attachment.
I repeat I’m on firmware 1.0.2.8- lmanpunkJul 11, 2020Star
I am on the same firmware. Minimum of one drop per day. I do not believe Netgear will ever get the RAX200 to work correctly.
- RajaDajaJul 12, 2020Luminary
Once a day!
From my experiences F/W 1.0.2.8 is the most stable that allows ipv6. Have you tried downloading & installing firmware from Netgear.com(downloads) then factory reset afterwards?
