timbo8391's avatar
timbo8391
AX12 Router Won't Connect to Comcast Cable Modem
I've got a Comcast Arris cable modem and configured it for bridge mode. I connect it to my AX12 router and I get an internet light on the router so everything looks good. However, I can't connect to the internet. I've rebooted both modem and router several times with no change. If I use the Comcast router everything works but I'd rather use my AX12. The AX12 also is working since I have used it with another modem. Does anyone know what might be going on?
1 Reply
  • FURRYe38's avatar
    Please post about this over in the RAX forum:
    https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
    Good Luck.
