tedlums
Aug 28, 2019Aspirant
AX12 very slow ping/latency
ax12 latency too high to run hulu. error occurs on multiple tv's so not a tv issue... tried unplugging for 30 mins and latency dropped some but still have error and can not play hulu. reset factory d...
Aug 28, 2019Guru - Experienced User
I shouldn't have said the 160hz wide channels won't all it to connect. Its just that the tv might not recognize/connect and default back to the 2.4ghz channels which have lower speeds/bandwidth for streaming.
tedlums
Aug 29, 2019Aspirant
the router does usually show tv connected at 2.4, i switched to 5g and no improvement
