Zapallin
Nov 04, 2019Aspirant
AX12 WiFi router disappear from WiFi list
The WiFi name disappeared from the list, there is internet for all wired devices but no WiFi network shows up on the list. I have reboot it, disconnected power, connected remotely to the router and re...
Zapallin
The wifi icon is lit, when i go to the list of wifi in my cell or laptop the name does not appear at all. In the netgear app everyting looks like is working fine. Every device that i ahve connected to it with wire is working fine.
Thank you so much for helping, i am basically ignorant on this.
well, apparently i cant attached files either, something about teh extension not matching....
Christian_R
Nov 06, 2019NETGEAR Employee Retired
Hi Zapallin,
Are you able to insert a photo using the photo option?
Christian
